Någon som vet om det bara är att ta fronten och lamporna från en ek99-> och smälla på en 96 tex?
eller måste huv och framskärmarna också bytas?
ek 96-98 vs 99-01
Daniel Skevarp
Honda Accord -2009
Honda S2000 - 2005
Toyota Auris - 2007 (tantens)
Honda Accord -2009
Honda S2000 - 2005
Tjena Infra!
Detta kanske kan hjälpa dig, jag fann det på ClubCivic.com.
Differences in Body and Interior
Exterior
96-98
Front Bumper (different sized lower grill and no brake ducts, a.k.a. "side vents")
Front headlights (less aerodynamic and blinkers have a "foggy glass cover" and an amber reflector strip and an amber covering for the blinker bulb inside the housing)
Front Upper Grill (smaller in both length and width)
Hood and Fenders (where they meet the front bumper and headlights, they are differently sized)
Tailights (the blinker and a small portion of the inner tail lights near the reverse lights have amber covering)
Rear Bumper (the lower lip of the rear bumper curves underneath the car)
99-00
Front Bumper (different sized lower grill and brake ducts capable of holding OEM foglights)
Front Headlights (more aerodynamic and have orange blinker bulbs with no amber covering and no amber reflector strip, but have a small amber reflector in the inner chrome wall of the blinker)
Front Upper Grill (larger in length and width)
Taillights (the complete bottom half the light is whited out)
Rear Bumper (the lower lip of the rear bumper curves in then outward a tiny bit from the car)
Interior
96-98
Radio/A/C/Heat Controls (the knobs used to control the temperature of the interior of the car are all located beneath the radio and the CD attachment for the radio is located directly in front of the cupholders in front of the transmission knob)
■ keyless entry is managed by factory head unit
99-00
Radio/A/C/Heat Controls (the knobs used to control the temperature of the interior of teh car are located BOTH to the left and below the radio and the CD attachment for the radio is located in the head unit leaving a storage space directly in front of the cupholders in front of the transmission knob)
■ keyless entry is a part of it's own system
■ Dome light comes on when you remove the key, whereas in the 96-98, it doesn't..
■ Map lights above rear view mirror where the 96-98 does not..
■ Corner lights blink with keyless entry..
Exterior
96-98
99-00
Interior
96-98
99-00
Jonatan Forsberg
Härnösand
Härnösand
