Honda´s 2.5L, 5 cyliders motor?
Clabbe
Bil: RD9
Namn: Клабе Бюрстром
Sprang på den här motorn när jag kollade runt på lite bilar i U.S...
Har aldrig hört talas om den tidigare...
Försöker hitta info om den men det är inte så lätt...
Nån som kan fylla på?
* Water cooled, 4 stroke single overhead cam gasoline engine
* It has an inline 5-cylinder 30 degree slant mount cylinder arrangement
* The bore and stroke is 85.0 x 86.4 mm
* The actual displacement is 2,451 cubic centimetres or 149 cubic inches
* The compression ratio is 9.0:1
* The valve train is belt driven with a single overhead cam and 4 valves per cylinder
* The lubrication system is a forced and wet sump trochoid pump
* This engine requires UNLEADED grade gasoline with a 91 Pump Octane Number or higher
Engine Type: 2.5-litre,SOHC, 20 valve, inline 5 cylinder
Horsepower (SAE Net): 196 hp @ 6300rpm
Torque (SAE Net): 185lbs-ft @ 3900rpm
Redline: 6800rpm
Fuel Cutoff: 7100rpm
Engine Block: Aluminum alloy with cast iron cykinder liners
Cylinder Heads : Aluminum alloy
Благодаря мутра!
MikaelR.
Bil: CR-V 2013
Namn: Mikael Rautio
Hittade lite info tydligen en G25A. Sitter i bl.a. Vigor, Rafagra.
<a href="http://www.honda.co.jp/factbook/auto/IN ... 2_016.html" target="_blank">http://www.honda.co.jp/factbook/auto/IN ... 16.html</a>
Edit :
Tycker Vigor ser ut som en legend nästan....
<a href="http://www.auto.vl.ru/catalog/honda/vigor/1993_8/photo/" target="_blank">http://www.auto.vl.ru/catalog/honda/vig ... /photo/</a>
Mikael Rautio
*SÅLD*Civic Type R -07
BMW 525 -89
*SÅLD*CRX VTi -92
Fiat 124SC -72
Mercedes 280S -68
*SÅLD*Civic 1.5 GL -89
*SÅLD*BMW M5 -90
*SÅLD*Kawasaki ZX6-R -99
*SÅLD*Alfa Romeo 164 QV-92
*SÅLD*BMW 323i -82
*SÅLD*Fiat 124SC -75
