Stor monitor!
c0k3
Bil: Honda Jazz-04
Namn: Marcus Claesson
Tänkte skaffa en större monitor till datorn. En 24" hade jag tänkt mig. Använder datorn till rätt mycket filmtittande och sånt. (har ingen tv)
Så är det nån som har några erfarenheter utav dessa monitorer? Har kikat lite på denna
<a href="http://www.eis.nu/cgi-bin/eis/eis.cgi?3 ... 2&32906510" target="_blank">http://www.eis.nu/cgi-bin/eis/eis.cgi?3 ... 2906510</a>
tycker den verkar vara ett rätt bra alternativ med tanke på priset och prestandan.
PRIS: 3699:-
Panel: SEC LTM240CT01
Design: Line Value
Pixel / Dot Pitch: 0.27mm x 0.27mm
Display Area: 518.4mm x 324mm
Brightness: 300 cd/m
Contrast Ratio: 3000:1(DCR)
Typ. Response Time (tr): 5ms
Viewing Angle: CR=10: 160/160
Compatibility: VESA, VGA,SVGA,XGA, SXGA, WXGA, WSXGA ,WUXGA, Mac
Scanning Frequency: Horizontal: 30K%7E83KHz, Vertical 55-75 Hz
Pixel Frequency: 165MHz
Maximum Resolution: 1920x1200.60Hz
Recommended Resolution: 1920x1200.60Hz
Resolutions Supported: 720x400@70Hz, 640x480.60/75Hz, 800x600.60/75Hz,
1024x768.60/70/75Hz, 1280x1024.60/75Hz, 1440x900.60Hz, 1680x1050.60Hz,
1600x1200.60Hz, 1920x1080.60Hz
Colors: 16.7M
Signal Input: Analog: 0.7Vp-p(standard), 75 OHM, Positive & DVI-D Digital Interface (TMDS)
Connectors: RGB Signal: 15-pin D-sub
Power: 3-pin Plug(Chinese Standard)
DVI-D: 24-pin DVI-D
Power Source: Power Input: Universal 110%7E240VAC, 50/60Hz
Power Consumption: 90 Watts (Max)
Plug & Play: DDC1/2B/CI
EPA ENERGY STAR : yes
User Control: Source, AUTO Config,Eco/down,up,Menu,Power
Function: Brightness, Contrast, Eco Mode,Gamma(1,2,3),DCR,Focus,
Clock, H/V Position, Color Temperature (Cool,Warm,Normal,sRGB,RGBYCM),
Color Boost(Full Enhance, Nature Skin, Green Field, Sky Blue, Auto Detect, Demo),
Picture Boost(Frame Size, Brightness, Contrast, Hue, Saturation, H/V Position,
Bright Frame on/off), OSD Setup(H/V position, Timeout, Language), Input Select,
AUTO Config,Reset,Information
Dennies
Namn: Dennis Gullberg
faktan ser helt normal ut
men har du tittat på några 24" skärmar, många är riktigt klumpiga jämfört med 22 eller annat, ser ut som mindre lcd tvs.
Personligen ska jag satsa på en bra 22" istället för en 24".
Dennis Gullberg
Team Helsingborg
Civic EG Lsi 92 Grå *såld*
Civic EG Lsi 95 Röd *skrot*
Civic EG Lsi 92 Röd *såld*
Del Sol Vti 92 Röd *såld*
c0k3
Bil: Honda Jazz-04
jag har en 19" som jag har på skrivbordet, 24" tänkte jag ha på väggen å koppla på när ja glor på film. så den får gärna se ut som en mindre lcd
Krister
Om den bara skall användas till film så är det väl billigare att köpa en LCD-TV?
Då får du ju även tv-mottagare i den så du kan se på vanlig tv också om andan faller på.
Honda CBR1000RA Svart -10
c0k3
Bil: Honda Jazz-04
Krister skrev:Om den bara skall användas till film så är det väl billigare att köpa en LCD-TV?
Vanlig LCD har oftat inte DVI-D ingång. Har letat runt, och priset ligger ungefär det samma. Går iaf inget bra på tv, så måste man ju betala tv-avgift då oxå...
Krister
HDMI brukar funka bra vad jag vet... DVI-D till HDMI då alltså.
Men visst, om du inte vill ha nån tuner så kör på monitor.
MagnusL
Bil: Accord 99
Namn: Magnus Lovgren
#892
2008 wrx sti
c0k3
Bil: Honda Jazz-04
gnagis
Bil: Civic X
Namn: Daniel Svensson
hijackar tråden lite och tänkte höra om någon har något att säga om dessa.....
<a href="http://www.webhallen.com/prod.php?id=84207" target="_blank">http://www.webhallen.com/prod.php?id=84207</a>
ska ha nya skärmar på jobbet
Krister
Om det är till jobbet så hade jag kört med kända märken, är en spottstyver mer i pengar då ni ändå får räkna bort momsen.
Typ LG, HP, Dell, Samsung har allihopa bra skärmar.
Fujitsu-Siemens kan ju knappt bygga datorer så deras skärmar vete fan om jag hade provat på.
