Apexi AFC Neo Bränsle/VTec styrning
Har nu valt att gå på en annan inriktining då dessutom inte ens har VTec i min bil..
Köpte den begagnad fullt fungerande och har fortfarande original förpackning kvar..
Kopierar lite info från deras hemsida fär.
The AFC NEO marks the newest edition to the world famous Super AFC line of piggy back fuel controllers. Building upon the powerful SAFC II, the AFC NEO has taken piggy back style fuel control to a new level. The AFC NEO boasts an incredible 16 points of user definable fuel correction. VTEC control has also been incorporated for Honda/Acura applications. A complete monitor mode is also available to keep the driver/tuner informed of critical engine data.
Features include:
- Completely new case design
- Compact design
- Incorporates both AFC and VAFC functions in one unit
- 16 point fuel correction
- Color FED display
- User defined button and background colors
- Inverted "anti-glare" screen
Key functions include:
MONITOR MODE-
* RPM
* Throttle
* Battery voltage
* Correction %
* Air flow %
* Pressure
* Karmann
* VTEC
SETTING MODE-
* Air map
* Air map graph
* Throttle point
* Deceleration air
* VTEC control
* VTEC unmatch
ETC MODE-
* Model select
* Mode select
* Car select
* Sensor select
* Analog scale
* Warning set
* Display set
* Sensor check
CONCEPT:
High resolution fuel control with integrated VTEC control.
CHARACTERISTICS:
Revolutionary color FED display easily customized by the user. *Not compatible with i-VTEC for controlling i-VTEC (can still be used as a fuel controller)*
Söker 2500Kr för den men är inte omöjlig...
Enklast är att nå mig via mailen på: ellej86@hotmail.com
Men går även att ringa på: 0733930577
Features include:
- Compact design
- Color FED display
MONITOR MODE-
* RPM
* Throttle
* Battery voltage
* Correction %
* Air flow %
* Pressure
* Karmann
* VTEC
SETTING MODE-
* Air map
* Air map graph
* Throttle point
* Deceleration air
* VTEC control
* VTEC unmatch
ETC MODE-
* Model select
* Mode select
* Car select
* Sensor select
* Analog scale
* Warning set
* Display set
* Sensor check
CONCEPT:
CHARACTERISTICS:
