s: T1R Coilovers till DC5/EP3
Martin_M
Bil: del Sol K24
Namn: Martin Mogren
Has thanked: 63 times
Been thanked: 22 times
Dem är till DC5 men passar även till EP3. Mer info kan ges vid intresse..
Dem är sprillans nya, endast testmonterade en gång.
En ventil skruv va trasig när dem kom till sverige men jag har bytt på två dämpare.
Klistrar in lite info:
Specifically designed for Time Attack (Best lap) purposes. 46mm piston mono-tube is used with 52mm casing for wide range tunability. Features 36 way compression & rebound single adjustable, therefore there will be sufficent adjustment for suspension fine tuning.
Shock body and components are made out of CNC machined chromoly steel, good heat dissiapation and minimize addtional weight.
T1R springs are CNC wounded with cold formed SA9254 steel (Very strong and durable). All springs are powdercoated to prevent corrosion.
Pris: 11 000kr [plus ev frakt]
Säljer dem endast för jag ska ha annat.
Bil:
Honda del Sol -95
Honda CR-V 1.6D -16
