Integra VTi-R ?
- Chrille79
- Bil: CH1
- Namn: Christian Roskjaer
- Has thanked: 11 times
- Been thanked: 24 times
Vad är det för nåt? Är ju en 1.8l.
Hitta några här:
<a href="http://www.drive.com.au/seo/used/result ... tegra&so=1" target="_blank">http://www.drive.com.au/seo/used/result ... ra&so=1</a>
Hitta några här:
Gammal räv...
Första tanken som slog mig var att de är motsvarigheten till amerikanska GSR? Dvs 1,8l och 169hk. Men jag kan ju vara helt ute och snurra....
Per Björe-Dahl, Göteborg
titta vad jag hittade...å all den infon fanns på den sidan som de va länkat till här ovan...
Standard Specifications:
Make HONDA
Family INTEGRA
Model Variant VTi R
Car Series
Year 1999
Doors and Body Style 2D COUPE
Engine Size 1.8litres (1797 cc)
Fuel System MULTI POINT F/INJ
Cylinders 4
Driven Wheels FWD
Std Transmission 5M
Optional Transmission
Standard Features Airbag Driver, Airbag Passenger, Anti-lock Braking, Air Conditioning, Alloy Wheels, Central Locking, Metallic Paint, Power Mirrors, Power Steering, Power Sunroof, Power Windows, Radio Cassette with 4 Speakers
Optional Features
Dealer Options CD
No Cost Options
Bore and Stroke 81x87.2mm
Power 125KW
Torque 173Nm
Weight to Power Ratio 9.41 : 1kg/kW
Front Brakes DV
Rear Brakes DC
Wheel Dimension 6.0Jx15
Turning Circle 10.6m
Compression Ratio 10.0
Final Ratio 4.4
Tank Capacity 50litres
Exterior Length 4380mm
Exterior Width 1710mm
Exterior Height 1335mm
Front Track 1475mm
Rear Track 1475mm
Wheel Base 2570mm
Front Suspension Ind; double wishbones with coil springs gas damper
Rear Suspension Ind; double wishbones with coil springs gas damper
Kerb Weight 1176kg
Ground Clearance 105mm
Seating Capacity 4
Highway Fuel Consumption 7.2 (lt/100km)
City Fuel Consumption 8.5 (lt/100km)
Towing Capacity 450kg
Release Date 01/07/1993
Discontinued Date 01/11/1999
New Price (standard) 40950
Average Kms 90
Model Run Disc-d Nov. Replaced by Type-R
VIN Location Centre Eng Bay Scuttle
Country of Origin
Make HONDA
Family INTEGRA
Model Variant VTi R
Car Series
Year 1999
Cylinders 4
Driven Wheels FWD
Std Transmission 5M
Optional Features
Dealer Options CD
No Cost Options
Power 125KW
Torque 173Nm
Front Brakes DV
Rear Brakes DC
Final Ratio 4.4
Front Track 1475mm
Rear Track 1475mm
Wheel Base 2570mm
Kerb Weight 1176kg
Seating Capacity 4
Average Kms 90
Country of Origin
- Namn: Andreas Jönsson
<!--QuoteBegin-SiR+23 Dec 2004, 16:47:11--><div class='quotetop'>QUOTE(SiR 4 23 Dec 2004, 16:47:11)</div><div class='quotemain'><!--QuoteEBegin-->vet iallafall att civic EK varianten med b16a2 motorn kallas civic vti-r i australien
och med 1,5 ils motorn 114 hk vti
<div align="right"><a href="index.php?act=findpost&pid=75503"><{POST_SNAPBACK}></a></div><!--QuoteEnd--></div><!--QuoteEEnd-->
Var kan man läsa om "1,5 ils motorn 114 hk vti"
Skicka gärna länk .. om du har mer info om detta.. aldrig hört förut.. [img]http://www.hondaklubben.com/forum/style ... >/wink.gif[/img]
verkar vara 1.6 L som e VTi... fast 88kw stämmer ju kolla:
<a href="http://www.drive.com.au/used/search/det ... mode=Specs" target="_blank">http://www.drive.com.au/used/search/det ... e=Specs</a>
- Chrille79
- Bil: CH1
<!--QuoteBegin-Kristian+23 Dec 2004, 17:17:40--><div class='quotetop'>QUOTE(Kristian 4 23 Dec 2004, 17:17:40)</div><div class='quotemain'><!--QuoteEBegin-->titta vad jag hittade...å all den infon fanns på den sidan som de va länkat till här ovan...
<div align="right"><a href="index.php?act=findpost&pid=75514"><{POST_SNAPBACK}></a></div><!--QuoteEnd--></div><!--QuoteEEnd-->
[img]http://www.hondaklubben.com/forum/style ... >/oops.gif[/img] Kolla inte så noga
Tackar för infon iaf [img]http://www.hondaklubben.com/forum/style ... humbup.gif[/img]
Gammal räv...
