Motorlampa lyser b16a2
- Has thanked: 146 times
Hittade en felkodslista men 32 finns inte.
0 Bad ECM (If CEL is on and no code or CEL stays on)
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - Manifold absolute pressure sensor
4 CKP - Crankshaft position sensor
5 MAP - Manifold absolute pressure sensor
6 ECT - Engine Coolant Temperature Sensor
7 TPS - Throttle position sensor
8 TDC - Top dead center sensor
9 CYP - Cylinder position sensor
10 IAT - Intake air temperature sensor
12 EGR - Exhaust gas recirculation lift valve
13 BARO - Atmospheric pressure sensor
14 IACV - Idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 Traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system or heated oxygen sensor circuit
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor
65 Secondary oxygen sensor heater
71 Random misfire cylinder 1
72 Random misfire cylinder 2
73 Random misfire cylinder 3
74 Random misfire cylinder 4
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor low input
92 Evaporative Emission Control System insufficient purge flow
16 Fuel injectors
23 Knock sensor
58 TDC sensor #2
