500kr eller bud.
Finns i Eslöv/Malmö men kan skickas.
MVH
P-H
Mer info:
General
•2/3/4 Channel Operation
•BassEngine®
•Subsonic Filter
•Bass EQ Circuit
•Crossover (HP/LP)
•MOSFET Power Supply
•DC-DC PWM Power Supply
•Discrete Pre-Amp Stage
•Double Buffered Pre-Amp Input Circuitry
•STAR Circuitry
•MultiMode™
•Top Mounted Blue LED Power/Status Indicator
•Duo B Feedback Circuitry
•Continuously Adjustable Gain Control
•Speaker Level Inputs
•Gold Plated Power Screw Terminals
Gold Plated Speaker Terminals
•Cross-Vented Chassis Design
SPECIFICATIONS
CEA-2006 Power Rating
•CEA-2006 Power Rating (40hm at 14.4V = 1%THD+N), S/N 60dBA (Ref. 1W into 4Ohm): 40x4
RMS Power (at 14.4V THD+N, 20Hz-200Hz)
•Per channel into 4 ohms: 40W x 4 (0.08% THD)
•Per channel into 2 ohms: 50W x 4 (0.3%)
•Bridged 4 ohms: 100W x 2 (0.3%)
•Total Max. Power: 360W
BassEngine® Sound Tuning
•Crossover Network: 18dB/oct
•Low/High Pass Crossover Frequency (Fixed): 80Hz
•Subsonic Filter (Fixed): 20Hz
•Bass EQ Frequency (Fixed): 50Hz
•Bass EQ Level (Adjustable): 0 - 12dB
General
•Power Requirements: 14.4V DC (11V to 16V)
•Frequency Response: 10Hz – 50kHz (+0, -1dB)
•Signal to Noise (S/N): 100dBA (referenced to rated power)
•Input Sensitivity (For Rated Power): 0.2V to 4.0V
•Slew Factor: Greater than 5
•Input Impedance: 10k Ohm
•Speaker Impedance: 4 or 2 Ohm (Stereo), 4 Ohm (Bridged)
•Dimensions (WxHxD): 232mm x 60mm x 267mm
•Dimensions (WxHxD): 9-1/5" x 2-2/5" x 10-1/2"
Weight: 2.64 Kg. (5 lbs. 13 oz)
