Hondata släpper större högtryckspump o spridare till FK2 & FK8
Äntligen kommer lösningen till FK2 k& FK8!
Jag som är svensk återförsäljare för HONDATA är extra stolt över att det är just de som är först på marknaden med denna produkt!! Detta kommer bli hur bra som helst!
Att nu kunna Köra FK på Etanol, massa mera effkt, i princip inga värmeproblem alls längre. Detta kommer få FK att gå som på steroider!
Etanol ger ca 60-70hk mer effekt på FK!
”Hondata announces the Civic Type R fuel system upgrade
We are thrilled to announce the Hondata Civic Type R fuel system upgrade. The upgrade consists of hardware and software components designed to deliver 25-30% more fuel flow and power over the stock fuel system. This system enables the Civic Type R to take the next logical step for a reliable, well engineered and thoroughly tested power increase.
• High flow direct injection fuel pump
• High flow ethanol rated in-tank low pressure fuel pump
• High flow high pressure fuel line
• High flow fuel injectors
• Low pressure fuel line
• Precision Hondata FlashPro software control
This kit is a plug and play direct bolt on using the stock fuel system. Everything can be returned to stock.
This has been tested on multiple vehicles for more than one year. On a vehicle with stock turbo and engine we could run full E85 without any fuel pump limitations. The stock engine torque increased 41% from 333 to 468 lb-ft and power increased 35% from 317 to 428 hp. On a vehicle with a turbo upgrade we have tested to over 500hp – a 60% power increase over stock.
Available January 2020
Price $2850 (including $150 core charge)
Faq
Do I need a FlashPro?
Yes
What vehicles does this cover?
The FK2 and FK8
What calibrations will FlashPro Manager come with?
Flex fuel and Full Race Turbo
Was this testing done with built engines?
Test vehicles had stock blocks
Are all the parts necessary?
Yes
Are the parts available separately?
No
What is the core charge for?
The high pressure fuel line
How long would a Hondata dealer take to install this kit?
4 hours
How long might it take me?
Most of the day
Can I return it to stock?
Yes
Do I need any special tools?
The in tank pump cage securing ring can be loosened with a large hammer and pry bar / screwdriver”
Faq
Yes
The FK2 and FK8
Yes
No
4 hours
Most of the day
Yes
- Bilagor
- FABB2366-46FC-4094-9515-0B8B23437F83.png (194.06 KiB) Visad 1755 gånger
- 36A67F23-215E-4E75-B2B9-B011290EF6AA.png (210.83 KiB) Visad 1755 gånger
- 929ABBD7-8AD6-4106-BBB2-2F101FC44147.png (258.36 KiB) Visad 1755 gånger
