Köpes: Mb6/Mc2 delar
Peggen
- Bil: Honda Accord Type-R
- Namn: Henrik Holmgren
- Has thanked: 2 times
Någon som har:
Orginal fjäderbensats runtom liggande eller bättre coilovers?
Insynsskydd/rullgardin?
Bagagerumsmatta (plast)
Centrallås dosa?
Centrallås dosa?
[font=Bradley Hand ITC]Peggen[/font]
- Has thanked: 146 times
Hej
Om inte jag minns fel körde jag med EK fjäderben med en extra distans bak på min MC2.
Peggen
Hejsan.
Så Ek3 fjäderben passar alltså till Vtin, vad för extra distans?
Vilket reg nummer på Mc2an hade du?
- Lärfors
- Bil: 89 Civic Shuttle (EE2)
- Namn: Andreas Lärfors
- Has thanked: 452 times
- Been thanked: 310 times
Vad är du ute efter? Ska du bara sänka bilen lite eller ska du köra bana?
Vad har du för budget?
Lite sökningar både här på forumet och Google:
viewtopic.php?f=5&t=74749&p=736436&hilit=mb6#p736436
https://civic5.com/forum/topic/1260-is- ... s-the-mc2/
https://civic5.com/forum/topic/1877-eg- ... on-on-mb6/Is MB6 suspension springs and struts the same as the MC2?
Hey, yes they are the same only difference between the two cars suspension wise is that the MC2 has no anti roll bar on the rear.
Struts, springs etc are the same.
EK Coilovers can fit MB6.
The front is the same as the EG / EK. The rear have the same fork size as the EK (40mm).
However, because the MB6 standard rear suspension are longer than the EK, the range of height adjustment will not be correct.
if you get a set EK coilovers, you won't have any room to play with them.
As most likely the highest point of adjustment will only be where it is acceptable on the MB6.
You can get away a little using a Dual Perch Coilovers like MeisterR Zeta-S as you can adjust the ride height and the spring pre-load...
On a single perch coilovers such as Tein Super Street... it will mean the rear springs will have be need to have massive amount of pre-load in them just to keep the ride height to what you need.
In the end, it depends on what you are looking for.
If you are looking for cheap drop, then the EK coilovers will "fit"; but it doesn't mean it will be "right" on the MB6.
Peggen
Jag är ute efter orginal fjädring/höjd på bilen. Det sitter ett par helt slut/stumma TA coilovers på den som måste bort.
Lite säkning vore ju fint 2-4cm.
- Lärfors
Nu kanske jag svär lite i kyrkan men vill du komma billigt undan beställer du ju nya dämpare och (sänk)fjädrar från t.ex. Autodoc:
Dämpare:
https://www.autodoc.se/ridex/8002617
Fjäder: (fram)
https://www.autodoc.se/ridex/8262372
Sänkfjädrar:
https://www.autodoc.se/eibach/7431489
Dämpare:
Fjäder: (fram)
Sänkfjädrar:
